A programmable node-based system
for GPU-friendly applications.
Take a look at it
Take a look at Gratin
What is it?
Gratin is a programmable node-based system tailored to the creation, manipulation and animation of 2D/3D data in real-time time on GPUs. It is free, open source and relies on OpenGL and GLSL to ensure wide OS and GPU compatibility. It offers three levels of programmability (group, generic and plugin nodes) which make it adapted to the needs of experts and non-experts alike.
Here’s some stuff you can make with Gratin
Gratin is useful if you want to work with 2D compositing or 3D scene rendering
Image processing
The color palette of a target image (A) is applied to a source image (B), using global mean and variance properties. The image in (C) is obtained by directly writing a transfer function in GLSL inside a generic node.
____
3D rendering
Displacement mapping is applied to an input sphere, resulting in a 3D object. The images in (A) and (B) show two output renderings where shading effects are mixed based on surface curvature.
____
Source code (tested on Linux, MacOSX and Windows):
Download
Windows64 binaries:
Download
Bundle for MacOSX:
Download
Documentation (get started):
Download
For more technical information and a (read-only) access to the code repository, please visit this site
Gratin is licensed under the Mozilla Public License (MPL), v. 2.0. For more details, a copy of the MPL can be found here
Credits
Authors
  • Romain Vergne (romain[dot]vergne[at]inria[dot]fr): Website - design, core/node dev
  • Pascal Barla (pascal[dot]barla[at]inria[dot]fr): Website - design
Participants
  • Gautier Ciaudo - node dev
  • Jean Bourgeas - node dev, debug
  • Pierre Bénard - bundle macosx, debug
  • Simon Boyé - node dev, links with patate lib
  • Nicolas Mellado - links with patate lib
Special Thanks to ...
  • Daniel Holtmann-Rice for OpenGL versionning and OSX tests
  • Steven A. Cholewiak for OSX tests
  • Georges-Pierre Bonneau for OSX tests
  • Gael Guennebaud for Eigen tips
